Full Version: .strm and .m3u not working in Atlantis
Hi all
I understand that .strm and .m3u streams will not work with atlantis beta 1( I cant get them to work anyway), is there any simple way I can get these working without having to recompile anything, I watch a lot of football (UK Soccer) especially live matches of my beloved Liverpool FC, if someone could point in the right direction I would be most grateful, it would be a big improvement on just using winamp. Many thanks.
You're going to have to give more details. Debug Log, sample stream, state explicitly how you create and play the file. Basically as much detail as possible.
althekiller Wrote:You're going to have to give more details. Debug Log, sample stream, state explicitly how you create and play the file. Basically as much detail as possible.
Hi thanks for the reply
With xbmc on the xbox I was able to put my link for internet streams into a txt file and rename the txt file to .strm then I would goto the .strm file on my xbox and it would start to play the internet stream. In the first instance when I tried the same thing using xbmc on windows I hit the .strm file on me hard drive and nothing happens no streaming starts or anything.
Xbmc does not crash or breakdown or anything like that so no debug log is created. It just seems to me like its not supported in the atlantis build so what Im asking is is it possible to add support to it in the atlantis beta with out recompiling or should I wait for svn or another buildHuh Thanks
The log is created whenever XBMC is running, not only when it crashes. I've used both playlist types on the linux build but its possible there is a bug on the windows side. We're going to NEED to see the log.
.strm should work though it depends which streams are embedded. Post a debug log via pastebin and show us how to reproduce.
ok guys thanks again for the help
heres the part of the log that I think is correct I have for obvious reasons had xxxx as username and password as its a private stream I hope Ive got this right...
14:32:46 T:4056 M:1556389888 DEBUG: CFileItemList::Sort, sorting took 0 millis
14:32:46 T:1668 M:1556373504 DEBUG: thread start, auto delete: 0
14:32:46 T:288 M:1556332544 DEBUG: thread start, auto delete: 0
14:32:46 T:1668 M:1555628032 DEBUG: CThread:ConfusedtaticThread, deleting thread graphic context
14:32:46 T:1668 M:1555623936 DEBUG: Thread 1668 terminating
14:32:46 T:288 M:1555632128 DEBUG: CThread:ConfusedtaticThread, deleting thread graphic context
14:32:46 T:288 M:1555628032 DEBUG: Thread 288 terminating
14:32:47 T:4056 M:1555693568 DEBUG: Clearing cached fileitems [D:\TV_Movies_HD\streams\]
14:32:47 T:4056 M:1555693568 DEBUG: CGUIMediaWindow::GetDirectory (D:\TV_Movies_HD\streams\)
14:32:47 T:4056 M:1555693568 DEBUG: ParentPath = [D:\TV_Movies_HD\]
14:32:47 T:4056 M:1556082688 DEBUG: CFileItemList::Sort, sorting took 0 millis
14:32:47 T:3112 M:1556135936 DEBUG: thread start, auto delete: 0
14:32:47 T:3112 M:1555537920 DEBUG: CThread:ConfusedtaticThread, deleting thread graphic context
14:32:47 T:3112 M:1555791872 DEBUG: Thread 3112 terminating
14:32:49 T:4056 M:1551945728 DEBUG: NativeDllLoader: Loading: C:\Program Files\XBMC\system\libcurl.dll
14:32:49 T:4056 M:1551364096 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://88.80.6.242
14:32:49 T:4056 M:1551339520 DEBUG: Curl:: Debug About to connect() to 88.80.6.242 port 8092 (#0)
14:32:49 T:4056 M:1551339520 DEBUG: Curl:: Debug Trying 88.80.6.242...
14:32:49 T:4056 M:1551327232 DEBUG: Curl:: Debug connected
14:32:49 T:4056 M:1551327232 DEBUG: Curl:: Debug Connected to 88.80.6.242 (88.80.6.242) port 8092 (#0)
14:32:49 T:4056 M:1551323136 DEBUG: Curl:: Debug Server auth using Basic with user 'xxxxxxx'
14:32:49 T:4056 M:1551323136 DEBUG: Curl:: Debug HEAD /stream03.nsv HTTP/1.1
Authorization: Basic cHJhZ21hdGljOmFjdGlvbjEwMQ==
User-Agent: XBMC/pre-2.1 (compatible; MSIE 6.0; Windows NT 5.1; WinampMPEG/5.09)
Host: 88.80.6.242:8092
Accept: */*
Connection: keep-alive
14:32:50 T:4056 M:1551269888 DEBUG: Curl:: Debug The requested URL returned error: 400
14:32:50 T:4056 M:1551269888 DEBUG: Curl:: Debug Closing connection #0
14:32:50 T:4056 M:1551265792 DEBUG: Curl:: Debug HTTP response code said error
14:32:50 T:4056 M:1551265792 DEBUG: FileCurl::Close(0012DC84) http://xxxxxxxx:[email protected]:8092/stream03.nsv
14:32:50 T:4056 M:1551212544 DEBUG: CPlayerCoreFactor::GetPlayers(http://xxxxxxx:[email protected]:8092/stream03.nsv)
14:32:50 T:4056 M:1550495744 ERROR: CAudioDecoder: Unable to Init Codec while loading file http://xxxxxxxx:[email protected]:8092/stream03.nsv
14:32:50 T:4056 M:1551204352 ERROR: Playlist Player: skipping unplayable item: 0, path [http://xxxxxxxx:[email protected]:8092/stream03.nsv]
14:33:00 T:4056 M:1551073280 DEBUG: Curl:: Debug About to connect() to 88.80.6.242 port 8092 (#0)
14:33:00 T:4056 M:1551134720 DEBUG: Curl:: Debug Trying 88.80.6.242...
14:33:00 T:4056 M:1551134720 DEBUG: Curl:: Debug connected
14:33:00 T:4056 M:1551134720 DEBUG: Curl:: Debug Connected to 88.80.6.242 (88.80.6.242) port 8092 (#0)
14:33:00 T:4056 M:1551134720 DEBUG: Curl:: Debug Server auth using Basic with user 'xxxxxxxx'
14:33:00 T:4056 M:1551134720 DEBUG: Curl:: Debug HEAD /stream03.nsv HTTP/1.1
Accept: */*
14:33:01 T:4056 M:1551155200 DEBUG: Curl:: Debug The requested URL returned error: 400
14:33:01 T:4056 M:1551155200 DEBUG: Curl:: Debug Closing connection #0
14:33:01 T:4056 M:1551155200 DEBUG: Curl:: Debug HTTP response code said error
14:33:01 T:4056 M:1551155200 DEBUG: FileCurl::Close(0012DC84) http://xxxxxx:[email protected]
14:33:01 T:4056 M:1551106048 DEBUG: CPlayerCoreFactor::GetPlayers(http://xxxxxxx:[email protected]:8092/stream03.nsv)
14:33:01 T:4056 M:1550430208 ERROR: CAudioDecoder: Unable to Init Codec while loading file http://xxxxxxxx:[email protected]:8092/stream03.nsv
14:33:01 T:4056 M:1551142912 ERROR: Playlist Player: skipping unplayable item: 0, path [http://xxxxxxxx:[email protected]:8092/stream03.nsv]
14:33:04 T:2564 M:1551085568 DEBUG: CThread:ConfusedtaticThread, deleting thread graphic context
14:33:04 T:2564 M:1551085568 DEBUG: Thread 2564 terminating
14:33:31 T:4056 M:1552678912 INFO: XCURL:Big GrinllLibCurlGlobal::CheckIdle - Closing session to http ://88.80.6.242 (easy=055D4460, multi=00000000)
14:34:01 T:4056 M:1541595136 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\libcurl.dll)
14:34:01 T:4056 M:1541595136 DEBUG: NativeDllLoader: Unloading: libcurl.dll
As you can see the GUI part seems to know that Im clicking the stream and it seems like it is going to connect but no matter what I do nothing comes up no stream nothing but XBMC doesnt crash or do anything strange.
Thanks again guys for all the help its much appreciated. Hopefully you clever lads will be able to see whats wrong Big Grin
Full log please! And use a pastesite this time!
http response code 400 means a malformed request done by the client (XBMC).
Did you tried this URL with another player?
And as althekiller said please let us decide which is the important part and post the full log on pastebin.
Thanks,
WiSo
WiSo Wrote:http response code 400 means a malformed request done by the client (XBMC).
Thanks,
WiSo
Hi Wiso thanks for you input..
To answer you question yes it works perfectly in winamp and VLC without any problems at all, I have pasted another instance of the log which was generated and did exactly as I did before the log is at
http://pastesite.com/2244
Many thanks again guys for all the help..
I forgot the most important one. Please post the stream filename (I guess I see it in the logfile) and the content to test it.
WiSo Wrote:I forgot the most important one. Please post the stream filename (I guess I see it in the logfile) and the content to test it.
I can post the m3u file but I cant post the content as its streamed live! Its football live streams (you call it soccer) so Im unable to post the content, unless Im getting the wrong end of the stick by what you are saying Oo I have checked again on my xbox and the streams work fine in that version of XBMC aswell as with winamp and VLC as I have said so Im guessing its got to be something platform based, I will however go and test the Mac and linux version before I make that assumption though and report back..
Sorry maybe the wrong term Cool
Yes please post the m3u file for testing.
