Full Version: How to migrate custom menus from Leia/Nox to Nexus/Nox
I finally migrated from Kodi Leia 18.8 using Aeon Nox (7.0.9) to Kodi Neux 20.2 using Aeon (9.0.1). I wanted this to be a clean install so I moved v18 to another PC for reference before uninstalling and then uninstalled on main PC.
I've installed all the addons and figured out how to bring in all the Playlists and Sources. I've also gone through and manually done a lot of tweaks.
What I don't want to do is manually setup all my main and sub menu's and their settings (Skin Settings->Main Menu->Set the Aeon Nox main menu). I've done a search in File Explore for some of the custom menu names in hopes that I would find the xml file that holds them, but no luck.
Would someone please share how I can bring across the custom menus?
I have not tested this in awhile but copying the skin shortcuts userdata/addon_data folder should work. Some things might have to be fixed due to whatever changed in between Leia to Nexus tho.
