I'm using beta one of Kodi 21
Unfortunately I just added some movies to my DVD Library and for some reason the movie scraper will not work I get the following error Errno 11001
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
I found the problem if I go into System > then internet accesss anmd turn that on I lose access to the web
Are you only using Kodi to scrape or another program and have Kodi scrape the metadata from the folder?
