Should you add an extension to the folder or / and file name if a film is in another language, e.g. in English? What should it be like and where should it be located?
I have a Foreign Language 'smart playlist', that teases out language other than english.
Smart playlists (wiki)
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="movies">
<name>Foreign Language</name>
<match>all</match>
<rule field="path" operator="startswith">
<value>J:\Foreign\</value>
</rule>
<rule field="audiolanguage" operator="isnot">
<value>english</value>
</rule>
<order direction="ascending">country</order>
</smartplaylist>
You can also put all Foreign Language into one source folder and use a smart playlist with a 'path' to source rule as the example does.
Tags are also a possibility along with genre to tease out the files.
Tags (wiki)
If you add some marker in the title, you could use that with a playlist, then save the playlist to favourites or add it to your home window (skin dependant).
OK, thank you very much, also for the code!
And do I have to add the name of the language to the movie folder and / or video file?
