Full Version: Issue with weblate and github script for my skin Copacetic
Hi @Gade, I'm having an issue with my skin where some sort of automation seems to be duplicating some of the translations and it keeps making pull requests but if I approve them the text string is getting longer and longer. You can see what I mean if you look through the recent history on this translation here:
https://kodi.weblate.cloud/translate/kod...on#history
There are three it's doing this for, the es-es, fr_fr and it_it descriptions in my addons.xml file. Here are the other two.
https://kodi.weblate.cloud/translate/kod...2Cposition
I was approving the pull requests before assuming they were legit updates, it was only after a while I realised they were coming through too quickly and then when I looked into them it was just duplicating the value xyz [cr] xyz [cr] xyz adding another iteration each time.
Do you know where I've gone wrong or what I can do to rectify? I've made a suggestion to have the translations updated on Weblate although didn't have permission to make the change directly, but looking in the system it looks like it was some sort of automation responsible for making the erroneous updates so I'm worried it might happen again as it looks like the Spanish one was previously fixed by jalvarado0.eses three months ago, then it started happening again in the past 24 hours.
Thanks for any light you or anyone else can shed on this!
