When I enable the master lock function in the interface settings, all my icons disappear in "Favorites" and the screen is dim. If I blindly click inside the window, the favorites that I saved still work. When I disable the lock function, all the icons reappear and everything is back to normal. Is there a solution to this ?
I should add that when I use the Kodi default skin, and set the Master Lock function, this does not happen. I have even tried setting it up in the default skin and changing back to aeon Tajo, but I get the same results.
I can confirm your issue, I will investigate and try to fix it, thanks!
Update: Issue found, it will be fixed in the next Omega version.
(2023-11-21, 21:06)manfeed Wrote: [ -> ]I can confirm your issue, I will investigate and try to fix it, thanks!
Thank You! I Love the aeon Tajo skin for it user friendliness and it's great layout.
