Full Version: Show on Library isn't deleting
I use TMDB helper to add shows to my library.
I use Arctic Zephyr as my skin and I have a widget that's my Library.
I have " allow file renaming and deletion" enabled.
I remove the show and it doesn't appear in the Library if I go into there using Kodi. But on the AZ widget, it still displays the show. I've deleted the folder, .strm files, and nothing.
It seems the problem is the Arctic Zephyr widget to display the library.
Is it or something else?
