2023-12-27, 02:29
Hi all,
i have started to use my previously working Kodi setup again in the last few days (probably not used it for around 6 months) and found somehow an issue which was not previously present has started to occur.
When I open the Windows Kodi app, it hangs on the splash screen (when enabled) for around 10 seconds until the main menu displays, I also get hangs of a similar duration when accessing library menus which is making the experience very unresponsive.
I am running Kodi 20.2.0 on Windows 10 with a MyVideos121 and MyMusic82 running on MySQL 5.7.28 on Ubuntu 19.04. I have two Windows 10 PCs as clients and both of them have the same issue. The Ubuntu Server is also running Zoneminder (and always has) which uses a MySQL database, there are no issues with the operation of that system
I have changed the log level to 2 and uploaded a log file here . This log file is for the initial load of the Kodi application up to and past the point of the initial hang upon loading the app. I note that once the menu in the app appears, no further information is posted to the log file (I left open in Notepad++ which tells you that the file you have open has changed as Kodi logs to it)
I've uploaded a second log here which includes the same as above but then some logging relating to me navigating around the menus. I opened the TV Shows --> Titles menu and counted a 10 second delay in the menu opening. I can't see an obvious bottleneck in the log suggesting what the delay might have been related to
my mysql error.log has what are maybe pertinent warnings (192.138.2.3 is the Windows machine the client is running on)
As I have this issue across two clients, I am assuming this is a backend / database issue and have tried the following so far to attempt to resolve
Rebooted server - no difference
Renamed both MyVideos and MyMusic databases so Kodi creates new ones - New databases were created but no difference
Verified I can connect via MySQL Workbench and run queries - all seems OK
Started the application without an advancedsettings.xml - loads almost immediately
Given the above, I think I am looking at some sort of database server issue but I cannot see what - there doesn't appear to be an issue with the server as I can connect and query OK and the Zoneminder application is connecting and querying as expected.
Can anyone advise what the issue may be?
