Full Version: Problem with the games interface - can't load the same ROM twice
I'm having a weird problem with the games browser. When I load a ROM, then try to load the same ROM again, the second time the menu to select an emulator is completely blank and empty. If I close the emulator selection menu before opening the ROM, I can open it again just fine. However if I open the ROM, quit, and try to open the ROM again, the emulator selection menu is blank. I've tried just hitting enter in case the menu was there but invisible, but that doesn't do anything. Rebooting doesn't fix it. The only thing I've found that works is restoring to an older LibreELEC backup. What's really weird is that it seems to happen on a per ROM basis. I can open a ROM once, then the menu fails, but I can still open other ROMs just fine. But only once each. I tried several different consoles, and they're all affected the same way.
I'm running the latest version of Kodi, LibreELEC and Rapier on an Intel NUC 11. This is my first time trying this, so it's not something that worked before (as far as I know) and then broke. Estuary doesn't have this problem, so I think it must be an issue with Rapier somehow?
Successful interface load log - https://paste.kodi.tv/pavafedipe.kodi
Failed interface load log - https://paste.kodi.tv/latarupoqo.kodi
This line stood out to me.
2024-01-06 10:58:58.978 T:932     debug <general>: Using already stored xml root node for /storage/.kodi/addons/skin.rapier/720p/DialogSelect.xml
I tried deleting that file in case a bad version of it was cached or something weird like that, but it didn't seem to do anything. The menu still failed to load correctly. Other than that, I didn't see any actual error in the log.
Screenshot of blank menu:
