2024-01-07, 10:24
Using the Jellyfin add-on in add-on mode, and chapter extraction doesn't seem to work. It works fine on the same file when using SMB file share. I found this thread (https://emby.media/community/index.php?/...thin-kodi/) for Emby that sounds pretty similar, and it talks about Kodi blocking chapter extraction for http requests. Not sure if that's what's happening here. It's a direct play though so bandwidth should be fine for it to work. Alternatively, if Kodi could just use chapter images that Jellyfin builds, that may be even better. But I assume that's a bigger no.
