Kodi 20.2 Nexus
I have a question, why the Bookmark thumbnails are created on Windows, on Android and Android TV it does not work, there is only black frame.It can be fixed ?
Android & Android Tv
Windows
Would it be possible to move the Thumbnails/Video/Bookmarks folder to another location? . When you periodically clean (ez maintenance+) the Thumbnails folder, bookmarks are also deleted
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Android
I did everything as in the instructions, I am sending a link to the logfile
(2024-01-12, 19:24)Kasio Wrote: [ -> ]I am sending a link to the logfile
link doesn't work, appears you made the end part of the url all uppercase
confirm this is the correct log please
https://paste.kodi.tv/aronazepok
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
I didn't know there were banned additives, now it should be ok.
Sorry, I didn't notice, it's already been deleted
Kasio
Did u just made a new log and delete the banned addon from the line ? Instead of removing them from the your system?
(2024-01-12, 22:57)Sidewinder_2011 Wrote: [ -> ]Did u just made a new log and delete the banned addon from the line ? Instead of removing them from the your system?
doesn't matter, check the addon origin lines 4728-4914
(2024-01-12, 22:57)Sidewinder_2011 Wrote: [ -> ]@Kasio
Yes, I think I sent the older logfile by mistake, all banned add-ons are completely removed from the system.
See above , you need to post new clean log
