2024-01-25, 20:52
I have a NAS attached to my router. I've always added this server to KODI directly, but recently i found that if i add it via the Nvidia 'mount network storage' it is much faster than KODI / SMB. But I've found one downside...i can't write to the drive when i try to 'export library'. When it is mounted to the Nvidia shield, i do use the admin username/password so i should have the proper properties. I did find that you need to modify the settings for the KODI app via the nvidia shield (Apps/permissions/files and media/ allow all the time) as well as (remove permissions if app isn't used set to no)
