2024-02-15, 18:52
2024-02-16, 20:37
Yes. It’s a pity! I hope @manfeed will fix this soon, as the regular Kodi skin is sooo boring…imho
2024-02-24, 15:39
@UlfSchmidt @fede01_8
A very simple workaround is possible.
Download the zip :
https://github.com/manfeed/skin.aeon.taj.../nexus.zip
Then in the archive ZIP replace in file "addon.xml" line 3 :
by
rename archive "skin.aeon.tajo-nexus.zip" to "skin.aeon.tajo-omega.zip
You can install now "skin.aeon.tajo" with Kodi Omega Beta 3
PS : if you have already this skin installed. All your custom settings will be used
Download the zip :
xml:<import addon="xbmc.gui" version="5.15.0"/>
by
xml:<import addon="xbmc.gui" version="5.17.0"/>
