2024-02-22, 11:38
2024-02-22, 11:49
Try here... https://forum.kodi.tv/showthread.php?tid...pid3174988
The skinner will need to update the skin, but you can do a quick fix following the post above.
2024-02-23, 10:42
2024-04-07, 05:45
so i went to C:\Users\xxxx\AppData\Roaming\Kodi\addons\skin.rapier, and made the change to the addon.xml file : <import addon="xbmc.gui" version="5.17.0"/>
but when i try to Use the skin, Kodi crashes when i click "Yes" to keep the change
what am i doing wrong?
edit: NEVERMIND, i made the change to the xml, then reinstalled Omega and it's working now
2024-04-07, 05:51
ok, nevermind...i made the change to the xml then reinstalled Omega and it worked
2024-04-07, 23:49
best skin ever, please update reqularly.
2024-04-09, 20:48
Hi, using @Karellen's tutorial I got the Rapier skin working on Kodi v21 Omega. But unfortunately I have one more problem, which is the display of Favorites. I am not able to access them in Rapier in any way. Does anyone have any ideas on how to make this work?
2024-04-14, 10:34
work on Pegasus too
2024-04-14, 11:49
(2024-04-09, 20:48)mpavlis Wrote: [ -> ]Hi, using @Karellen's tutorial I got the Rapier skin working on Kodi v21 Omega. But unfortunately I have one more problem, which is the display of Favorites. I am not able to access them in Rapier in any way. Does anyone have any ideas on how to make this work?See here: Changes to the skinning engine for Kodi Omega (v21)
2024-04-21, 05:44
@Gade Is an official Omega update coming for Rapier?
2024-04-26, 19:02
Yes, please. Update your Skin. Otherwise my AndroidTV looks awfull. Rapier is just the Skin to go
