Voinage Wrote:Everyone has the lock up before end of rtmp stream problem and the buffering.
Welcome to the great majority.
Just stop the video 5 secs before the end and pause for a few seconds to buffer at the start.
Rtmp stream remains open.
i have some mostly problems with mms streams with latest xbmc.
mean after Caching it will not continoue to play, it goes automaticly to pause the mms stream.
then i must take again play to can watch the stream.
with nsv , or http streams i doesnt get this effect only with mms streams.
I don't know if this will help, but there has been a discussion on video streams hanging in the bug section for xbmc for xbox.
Here:
http://forum.xbmc.org/showthread.php?tid=30535
From what I've gathered it was narrowed down to the VideoOverlay.xml in the PMIII skin.
The temp solution is to switch to a another skin or overwrite the VideoOverlay.xml file with the one from 2007-11-04 T3CH.
Hope that helps. I noticed video streams playing much better when I overwrote the xml file.
--FC--
Voinage Wrote:Yeah i suppose i could release a version for the U.S xbmc users - but i`m in England and feel slighted that i have to use a fast proxy. I`ll tidy up my scruffy code and release them soon for the US users -- ^&%&%&^%^&%!!!! Geo checks.
Still planning on releasing this? If not how about a link to the pastebin of the current 'scruffy' code so we can fix it up and get it going without redoing everything you've already come up with?
justin tv didnt work for me either, i only updated my xbmc cause i stumbled across this topic when checkin if veetle and justin tv was playable on xbmc
still waitin for a way to play justin tv, ustream, veetle, TVU (used to work a few yrs ago) afreeca and uusee, on xbmc for all ma football. also would like to be able to play zatoo on xbmc.
Hmmm. When I select any act (2-x) I don't get a thing. It doesn't even freeze it just simply doesn't play. Using the latest popular build.
Do I need to run the Veoh-proxy script if in the US?
Veohproxy isn`t needed for the southpark plugin.
It may need fixing though, i`ll look at it over the weekend.
I'm not really sure if this is the right place to say this but have you considered ctv.ca?
Whats good about this is that ctv, tsn, discovery channel and the comedy network all use the same format
I think the format for the videos is
http://watch.channelname.ca/tvshowname/s...domnumbers
example of lost season 5 episode number 500. the episode is called destiny calls
I have no idea what the numbers at the end signify though. This example was clip2 of 5 if that helps
http://watch.ctv.ca/lost/season-5/lost-e...clip131833
another example
This one is on muchmusic.com the tv show is called celebrity rehab presents sober house. Its season 3 episode 1, clip 1 of 8. This one is odd because they list the episode number as 101 because this is a spin off of a show that has had two other seasons (thus sober house season 3)
http://watch.muchmusic.com/celebrity-reh...clip132380
