Is there a reason why release candidates are provided in Windows Store? I'd like to update to 20.5 and not to 21RC1
(2024-03-09, 13:48)SeBoss Wrote: [ -> ]Is there a reason why release candidates are provided in Windows Store? I'd like to update to 20.5 and not to 21RC1
Probably because its considered stable enough for people to use?
Why dont you download the version you want from kodi website?
Unable to install add-on from Kodi official repository.
Seriously? If you consider a version to be stable enough for people to use, it is a final. Especially in an official app store. If I want to test a release candidate, I install it manually from the website. I decided to use Kodi from Windows Store because of the auto update feature, but not to a non-final version.
I encountered a problem when using the Windows version under Windows 11:
When I open the movie list, it takes much longer to display the list (roundabout 10 secs) than with Kodi 20 (below 1 sec).
I use a mySQL database with about 2500 movies.
Any idea?
crazyturk You'll have to provide a bit more information, other than 'it doesn't install' (operating system, hardware, gfx engine, error codes etc.. without we have no clue)
crazyturk The version is solid & stable for most, and all the developers have reported it's good to go; reporting, release is after dev-con.
wwessel I actually found it faster with a larger collection, but then I don't utilize the mySQL database. Submit a proper debug log in the windows forum.
Just in case someone thinks that this RC1 isn't appreciated. What a wonderful slice of software.
I thank- all those involved in the continuing effort that is Kodi and welcome all the new features and fixes.
Thanks, the issue of not being able to connect to the repository has been fixed by CoreELEC.
I tested the brand new LibreELEC 11.95.1 bringing Kodi 21 RC1, but I got the same behaviour. It has nothing to do with the WIndows version, it's a general issue.
I compared the database schemas of MyVideos121 and MyVideos131, but I can't find the cause here. All indexes which are on v121 are on v131, too.
Maybe Kodi20 selects only the first entries when opening the list and the rest in the background, but Kodi21 the full set before displaying the list?
BTW: All other lists (Series, Musicvideos, Music) show the "normal" behaviour.
OK, problem & resolution found:
The index "ix_videoversion" on the new table "videoversion" had cardinality = 0. After analyzing the table all is working fine.
I guess something went wrong in migrating the database...
