Full Version: selectable/correct recognition of standardaudio for media flag "Audioquality"
Description:
A lot of movies/TV shows have multiple audio streams implemented. Like DualLanguage Releases or Multi. Kodi shows only highest quality available, not the mediastandardaudio language/stream set in the media file. In the settings you can even choose which language should be used like for the subtitles. (Original, Mediastandard or language itself) but apparently has no effect for the mediaflag for the audioquality.
Example:
Movie Bumblebee, German DL release, German in AC3 and English TrueHD streams. Kodi shows the TrueHD Flag.
Possible solution:
1.Switch under settings/audio to choose, which stream should be preferred like prioritize language/default track over quality or whatever the current deciding factor is.
3.Correct selection/recognition of audioquality by setting default audio/mediastandard in settings/audio (already there)
2.Selectable mediaflag(s) for audioquality
thank you for your great work
