Hi
How do i get Kodi 20.4 to make use of Pipewire ALSA to play TrueHD and DTS X formats. Previously on Fedora I use to use pasuspender to bypass pulse and use ALSA. However since F39 I am not able to use this. I am currently stuck with Dolby, Dolby ++ and DTS etc, no HD sound.
Looking forward to your input
You don't. Not supported on 20.x. Use a v21 nightly. When local alsa configuration is correct, it will work.
Hi rahul_01,
You may find changing the audio engine helpful. Set the environment variable KODI_AE_SINK to "alsa" and restart Kodi. Note: this variable will be replaced by a command argument to the kodi binary in the future. With the environment variable set I have been able to pass through True HD.
Fedora will get Kodi 21 starting with Fedora 41 but possibly with Fedora 40.
(2024-03-12, 06:28)mooninite Wrote: [ -> ] Note: this variable will be replaced by a command argument to the kodi binary in the future.
Thats interesting news! Do you know maybe when this will happen?
Hi how do I do this.
I was using pasuspender to force ALSA. However, since upgrading to F39 this didn't work because, the packages has been changed to the below
Installed Packages
pipewire.x86_64 1.0.3-1.fc39 @updates
pipewire-alsa.x86_64 1.0.3-1.fc39 @updates
pipewire-codec-aptx.x86_64 1.0.3-1.fc39 @rpmfusion-free-updates
pipewire-gstreamer.x86_64 1.0.3-1.fc39 @updates
pipewire-jack-audio-connection-kit.x86_64 1.0.3-1.fc39 @updates
pipewire-jack-audio-connection-kit-libs.x86_64 1.0.3-1.fc39 @updates
pipewire-libs.x86_64 1.0.3-1.fc39 @updates
pipewire-pulseaudio.x86_64 1.0.3-1.fc39 @updates
pipewire-utils.x86_64 1.0.3-1.fc39 @updates
pipewire0.2-libs.x86_64 0.2.7-10.fc39 @fedora
Can't wait for Kodi 21. But still a long way F40 or F41 to be released.
Start Kodi with "env KODI_AE_SINK=ALSA kodi" to force the Audioengine to use ALSA.
And hope, that this works out in Fedora. Under Lubuntu Kodi gets quite instable in this mode.
(2024-03-13, 16:32)contadino Wrote: [ -> ]Start Kodi with "env KODI_AE_SINK=ALSA kodi" to force the Audioengine to use ALSA.
Hi thanks for this. Ran with CLI as you suggested. But I am getting an error one or more items failed to play. I guess I will have to wait for Kodi 21. Praying that it gets launched soon.
I have pushed an update to Fedora 40 for Kodi 21 RC1, which will mean the final release of v21 will be available for Fedora 40. Fedora 40 is scheduled to be released near the end of April 2024.
