Hello,
Right now, I'm using Project Mayhem III skin in XBMC... but when I play some songs, I cannot find the "Play/Pause/Stop/etc" buttons. Where are they? I've looked everywhere. I cannot seem to find them.
Any help would be most appreciative.
Proper etiquette please.
Please wait at least 24hrs before bumping your own thread. That allows people from all around the world to read your post.
In keymap.xml u forgot to make button with XBMC.ActivateWindow(PlayerControls)
just add maping to this one and use ur control it should works
(i don`t check using this command)
anytime buttons play/stop etc on the keyboard and remote should work.
BAG_Ass Wrote:In keymap.xml u forgot to make button with XBMC.ActivateWindow(PlayerControls)
I don't have a remote tho, is there no onscreen controls in PH III
By default press M a keyboard or if you use PM3.HD it has buttons if you have mouse enabled
