Full Version: Kittmaster's Repo Updated to 1.0.09 - 6/20/2024
This splits the repo by build.
Be sure to update the Repo FIRST before any other pulls for the skin as the installation paths have now changed.
Allows for Omega install now, give it a whirl and report any issues. TY!
Chris
Quote:Update Instructions:
If you are having connection issues, be sure you are using the latest repository. Any repository prior to 1.0.08 will result in a connection failure!
  1. Main Menu
  2. System
  3. Add-ons
  4. Click > KittmasterRepo (Should already be there since this is an upgrade)
  5. Click to update/install > repository.kittmaster-1.0.08.zip or above that is listed there.
  1. Main Menu
  2. System
  3. Add-ons
  4. My add-ons > All > Scroll until you find "Kittmaster's Repo" > Select
  5. Right button will provide option to uninstall > Uninstall
  6. Download repository from Github and save to a folder your device can access: https://kittmaster.github.io/KittmasterRepo
  7. Select the listed .zip file that is shown at the link in step #6.
  8. Click into Add-ons
  9. Install from zip file
  10. Access to KittmasterRepo can now be accessed within Kodi from "Install from Repository"
  11. System
  12. Add-ons
  13. Kittmaster's Repo
  14. Look and feel
  15. Skin
  16. Madnox
I can't connect to the repo, Kodi Omega RC1
Quote:2024-03-11 08:46:47.050 T:18608    info <general>: Skipped 2 duplicate messages..
2024-03-11 08:46:47.050 T:18608   error <general>: Repository add-on repository.kittmaster does not have any directory matching 20.90.900 and won't be able to update/serve addons! Please fix the addon.xml definition
2024-03-11 08:46:47.992 T:18608    info <general>: Skipped 6 duplicate messages..
2024-03-11 08:46:47.992 T:18608 warning <general>: CGUIMediaWindow::OnMessage - updating in progress
2024-03-11 08:46:48.852 T:18608 warning <general>: CGUIWindowManager - CGUIWindowManager::HandleAction - ignoring action 107, because topmost modal dialog closing animation is running
2024-03-11 08:46:49.083 T:19620    info <general>: Skipped 16 duplicate messages..
2024-03-11 08:46:49.083 T:19620   error <general>: XFILE::CDirectory::GetDirectory - Error getting addons://repository.kittmaster/
2024-03-11 08:46:49.092 T:18608   error <general>: CGUIMediaWindow::GetDirectory(addons://repository.kittmaster/) failed
2024-03-11 08:46:49.093 T:18616   error <general>: Repository add-on repository.kittmaster does not have any directory matching 20.90.900 and won't be able to update/serve addons! Please fix the addon.xml definition
I'll have a look at it, thanks for the update. I'll post when I sort it out.
The last Repository 0.07 working on omega rc1.
I install the madnox skin and test it now, thanks
The repo has been pushed to .08, please update accordingly. I tested on all 3 builds > Matrix, Nexus, Omega and the skin updates and is seen as v20.00.11 on all 3 builds and installs correctly.
This resolves all issues repo related until Omega moves to release format which will require the repo min value to be bumped to support and remove all release candidates when that time arrives.
For now, good to go.
The repo is now 1.0.09 and should be flagging to update within Kodi.
The update includes removing Matrix from the Repo as the changes going forward will to become to divergent. Most of the changes will still run with Matrix, there just will be no more dedicated space that is updated regularly. The master is still there and can be used at any time for Matrix and downloaded as zip so you can always go back and have a source as needed.
The Nexus and Omega branches have been updated at this time as well.
Regards,
Chris
