Full Version: [PVR-Section] GUI for Instances - match the "Addon-list" enabled and disabled Icons
This is a FR for PVR-instances (better GUI)
Use a check box tick for enabled and X for disabled instances instead of (translated) text, similar to how addons show installed vs not installed.
Actually it looks like this:
The German translations show it at the end of the line which is a bit confusing on an already confusing dialog.
Here is a mockup, how it could be: (with english language on 20.2 Ubuntu flatpak)
changes:
1. add a checkbox ticked or "x" for enabled/disabled configs. It's easier to see, which config is enabled/disabled. Here 1 and 2 are enabled and 3 is disabled. The german dialog shows:
"Fallback_2" [Aktiviert] bearbeiten
which would be
"Fallback_2" [Enabled] edit
translated in english and not
Edit "Fallback_2" [Enabled]
like it is in english at the moment. "Edit" and "enabled" are not on the same place, which is confusing and not easy to see. That's why I suggest a checkbox.
2. remove "enabled/disabled" text from config-names
3. remove " from config-names
4. clicking on a m3u-entry should open edit (like it is now). Here you can enable/disable a config.
5. there may be a context menu to enable/disable a confg ... but this could be not worth the effort, as it is possible with 4.
Thx for taking it into consideration
FR created from this post and the following ones: https://forum.kodi.tv/showthread.php?tid...pid3178411
