Full Version: tv menu "the Aspect Ratio Settings" option to become grayed out and unavailable
playing certain files may cause "the Aspect Ratio Settings" option to become grayed out and unavailable
The following text is translated online and the expression is not very clear.
lg cx,webos5.5
Using Kodi v21.0 stable, all settings remain default and only dlna is enabled, dlna server:lg smartshare
Kodi uses DLNA to play the following two files, and when using the LG remote controller to call up the settings menu, "picture 1" will appear. At this point, "the Aspect Ratio Settings" option is grayed out and unavailable.
If using the built-in player of the TV, "the Aspect Ratio Settings" option is white and can enter the next level menu normally.
For this, I made two 10 second samples, Zip file, decompress pw as12
Download address
https://wwp.lanzout.com/i7gGW1zjbd5a
https://wwp.lanzout.com/iOnBM1zjbd7c
Hope to receive everyone's test results, thank you
"picture 1" Image
