Full Version: miss match metadata to the movies
Hello,
I'm new here and would like to ask for help with 2 movies that the Kodi with the default add-on for movies can't find correctly.
I have 206 movies, and I have an issue only with two: in the WALL-E, it didn't find the right movie, and shows in the "Movies" category the wrong one.
the "mini-adventures-of-winnie-the-pooh" can't be seen in the "Movies" category because it can't find any details on him.
I saved the movies in separate folders with the following names:
  • (Folder name) - Mini.Adventures.of.Winnie.the.Pooh.2011 -> (File name inside the folder) - mini-adventures-of-winnie-the-pooh.2011.1080p.BluRay.X264-AMIABLE.mkv
  • (Folder name) - wall-e.2008 -> (File name inside the folder) - wall-e.2008.1080p.BluRay.x264-HD1080.mkv
I tried with many add-ons but it didn't work...
someone can help me and check how I should name the folder or the file name to be able to see the right poster and the details on the movies?
(2024-06-01, 13:34)Kobi Shalom Wrote: [ -> ]Hello,
Keep your folder and file names the same.
Folder> Wall-E (2008)
File> Wall-E (2008).mkv
Wall-E is tricky to scan, I had to do a manual scan of the file.
Hello @Kobi Shalom
(2024-06-01, 13:34)Kobi Shalom Wrote: [ -> ]WALL-E (2008)
If the wrong movie is in your library, from the movie's Information Page, press the Refresh button and select the correct movie from the offered list.
(2024-06-01, 13:34)Kobi Shalom Wrote: [ -> ]Mini Adventures of Winnie the Pooh (2011)
This is a tv show, so it will not appear in movies. It needs to be in your tv show source and files named with the S01E01 convention.
