Full Version: How to edit a source to update the media library?
Hello,
I can't edit a source to be able to specify the folder type and update the media library accordingly, what should I do?
THANKS
(2024-06-09, 13:10)benxen Wrote: [ -> ]I can't edit a source to be able to specify the folder type and update the media library accordingly, what should I do?
Edit an existing source, or add a new source?
To edit, maybe this wiki page might help... https://kodi.wiki/view/Changing_Scrapers
Add a new source.
The link given is empty, no information available
The link is ok now but the item "change content" not exist on lg webos
(2024-06-09, 22:31)benxen Wrote: [ -> ]The link is ok now but the item "change content" not exist on lg webos
Yea, because that is for editing an existing source.
To create a new source, maybe this helps... https://kodi.wiki/view/HOW-TO:Create_Video_Library and you can probably jump to step 6 if all your media is correctly named
(2024-06-09, 22:26)benxen Wrote: [ -> ]The link given is empty, no information available
Sorry, I don't know what link you are referring to. The link to the wiki page?
Imagehttps://ibb.co/K70YZGf
adding scrape not availableImage
I understood, adding the scraper does not work on an upnp source but it is ok in smb
(2024-06-10, 09:44)benxen Wrote: [ -> ]understood, adding the scraper does not work on an upnp source but it is ok in smb
Correct. You cannot scrape media from a uPnP source. uPnP is it's own library.
You create a library from direct access network protocols like SMB, NFS etc.
Your image clearly shows a uPnP source, so scrapers don't work there. You just use the uPnP tree that is provided by whatever UPnP server you are using.
