Full Version: scraping repeatedly stuck with Kodi 21
After upgrading to 21 (LibreELEC 12), scraping is repeatedly getting stuck on some movie files and won't continue until I delete these. Movies are on a SMB volume. No such issues in the last decade of using this setup.
Here are the logs. Right now it's stuck on a file "Frankenstein (1931).avi" (but it's not showing in the logs AFAIK). This is a new folder, media type is correctly set to Movies, both Universal Movie Scraper and The Movie Database Python have this issue.
Please help.
Please enable debug mode for your log. Then upload it to Kodi Paste Site and provide the link. Don't give me a zip file.
There is something wrong with your library as it seems malformed. You have a number of weird entries and lookups that don't make sense and I wonder what/how you have been scraping your library. There is no way that has happened just from normal scraping.
Don't use Universal Movie scraper as it has problems. Stick with The Movie Database Python.
With all those weird errors, I think you are going to have to delete your existing library and start again.
Thanks, maybe these were leftovers from me trying to get Jellyfin for Kodi working (it sort of did, but was very slow), which I then removed in the recommended fashion (disable first, uninstall second, reboot kodi, clean library). In any case, after deleting the library, I am able to scrape it now. Thanks!
Great!! I'll mark this solved.
Thread marked solved.
