Full Version: Mysql/ MariaDB import / export issue
Hello, my library is over 10 years old and went thru several migrations and is extremely slow to library updates. I am trying to see whats the best way to create a new library from scratch and import the playcounts/ watched episodes etc. intact.
the import/export separate file option seems like the recommended approach by Kodi but I am curious to know, if I delete season 1 from a show from disk, will Kodi keep the watch and playcount history for the same? if so, how can I import this in to the new library when the actual files are not on the disk ?
main reason for seeking to do a clean upgrade is the library update is slow and the percentage progress goes back between 25-50-33 etc. for a long time.
hope this is easy to understand, please let me know if I am not clear...
thanks
No reply? did I just ask an impossible question ?
(2024-07-22, 16:28)crossrock Wrote: [ -> ]main reason for seeking to do a clean upgrade is the library update is slow
Can you provide the Debug Log and we might spot why the update library is slow.
(2024-07-22, 16:28)crossrock Wrote: [ -> ]if I delete season 1 from a show from disk, will Kodi keep the watch and playcount history for the same?
It will keep it in the library until you run a Clean Library, then the library entries will be deleted.
(2024-07-22, 16:28)crossrock Wrote: [ -> ]I am trying to see whats the best way to create a new library from scratch and import the playcounts/ watched episodes etc.
The Export to Separate Files is the best method for your library.
