Full Version: Kodi Radio add-on not working (network error) Android
I'm running Kodi 19.5 on an android TV box (Mygica).
The kodi radio add-on has always worked - unti now.  The last time I used it might have been a month or two ago.
Version 3.0.9+matrix.1
Kodi Add-on Repository
Right now, when I try to play any of "my stations" I get the double-circle (wait thing) for about 10, 15 seconds, then a small error box saying "Network error".  When I select anything from the main menu (Local Stations, Browse by genre, etc) the same thing happens.
I have another rado add-on (shout cast) and it seems to work, but I don't use it much because half the time I'll navigate to a station and try to play it and something happens and I'm kicked right out of Kodi.
Any ideas what's going on here?
Yes, it's broken. I suggest moving on to the replacement by @fivebanger.
Thanks for the info.  I installed the fivebanger repository (repository.fivebanger.zip) and from there installed the radiobrowser and it does work.
Is there a simple way to install a more comprehensive or complete station directory for this add-on?  One of the stations I have as a favorite for the default kodi radio add-on is not listed by fivebanger.  Would like to see more genre's also (only a single "Jazz" choice, for example).
(2024-08-19, 16:15)Sumguy Wrote: [ -> ]Is there a simple way to install a more comprehensive or complete station directory for this add-on?
Use the Search function. I have added about two dozen stations that I had in my old (now an orphan) radio add-on.
