Now i use XBMC_for_Windows-Atlantis-Beta_1
MC360 SKIN can use for this
Should work, try it and see.
But make sure you disable the mouse support in XBMC or it will throw spasms
Thanks , I already run it
And a question : how to remove youtube online video menu?
I don't like this....
There are lots of issues...since its not a xbox... I used it on mac and linux....but the skin has custom items kali...
I have since removed all the KAI stuff from the skin since its been removed from xbmc so it should work fine
Anyone know how to fix the gamer card? It wont download info anymore.
Jezz_X Wrote:I have since removed all the KAI stuff from the skin since its been removed from xbmc so it should work fine
Really? Xlink kai has been removed from XBMC :-o
Haven't tried it in a while since I got my 360 and live gold membership but that's really sad...
I'll have to get my hands on an old copy of XBMC to keep somewhere on my old xbox as I really did like using Kai on it.
Why did folks decide to take Kai out?
XBMCG33K Wrote:Anyone know how to fix the gamer card? It wont download info anymore.
I was under the impression that the latest svn version did work in downloading the gamercard info unless MS went and changed their site layout again
try the version from here its way newer than blackbolts site one
http://blackmarket.ictcsc.net/files/skins/
