I'm not able to scan a TV show folder. I select Set Content, TV SHOWS, click select, then scan for new content but nothing comes up. This is also the same for Movie folders. I tried looking for the log file but do not know where to find it.
Thanks for the quick reply. Did not find a Logs directory under ~/Library, created it. I will try to generate logs and will report back here.
salowais Wrote:Thanks for the quick reply. Did not find a Logs directory under ~/Library, created it. I will try to generate logs and will report back here.
ssh into the appletv
sudo find / -name xbmc.log -print
should get
/mnt/Scratch/Users/frontrow/Library/Logs/xbmc.log
From the debug log.
Quote:22:52:43 T:43796480 M: 40497152 INFO: Get URL: http://www.thetvdb.com/api/GetSeries.php...anguage=en
The file returned is an empty xml file as the show, season and episode and looking it up as the series name. My apologies for the silly newbishness, I'll play around with it and see if I can get anything.
