Full Version: Arctic Fuse 2
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
is it possible to add list view when using files mode and not the library (like in stock or original AZ skin)?
I can't seem configure it like that and see only 'tile'-based views with minimal information.
Why I always having TMDb Helper Error notification? I tried to reinstall it but still the same...
https://paste.kodi.tv/opetejanip
For some reason it does not show if I have already watched some content, be it a movie or an episode
Thank for the work
Is there any way to hide the kodi build at the bottom without modifying xml files? I can't access those files on a locked down android system
Hum, I prefer to see that info directly without any action, but I understand it doesn't fit your minimalistic and clean approach. Nevermind, all the best!
(2024-10-18, 14:54)CouchGuy Wrote: [ -> ]Why I always having TMDb Helper Error notification? I tried to reinstall it but still the same...
Because you're using a nightly version of Kodi Piers rather than a stable version of Kodi Omega and there is an issue in the version of Python it is using.
https://github.com/jurialmunkey/plugin.v...ssues/1251
(2024-10-19, 02:49)jurialmunkey Wrote: [ -> ]
That's what I thought. Thanks @jurialmunkey
I'm currently using Kodi 22 modified by @fritsch because of DD+ passthrough issue.
Might be a dumb question but Is it normal for some option to be available on one device and not another? For ex, on my firestick I can change the “wall orientation” between horizontal/vertical but the option is not there on my MacBook.
(2024-10-20, 03:08)amcottre Wrote: [ -> ]Might be a dumb question but Is it normal for some option to be available on one device and not another? For ex, on my firestick I can change the “wall orientation” between horizontal/vertical but the option is not there on my MacBook.
This option depends on your screen resolution.
You can only choose a vertical wall if your screen resolution has an 16:9 aspect ratio e.g. 1920x1080 (FHD) or 2560x1440 (2K) or 3840x2160 (4K).
That's because the skin is designed for 16:9 but gets away with working okay for other aspect ratios by only having views which expand on the horizontal axis. So a vertical wall would have weird alignment issues.
(2024-10-08, 23:05)HisAirness23 Wrote: [ -> ]Image
Could you share how you got the white box for HdrType to look like the VideoQuality?  I've tried several times and can't get it to work.  Usually ending up with the whole section being blank.
I'm trying to get HdrType and AudioCodec to be like yours.  Everything to the right of AudioCodec would then be like the pic below.
Got some help from another member in PM.  WIP but getting there.
(2024-10-18, 17:02)stayingarmed Wrote: [ -> ]Is there any way to hide the kodi build at the bottom without modifying xml files? I can't access those files on a locked down android system
@stayingarmed
On a locked Android system (>=11), such as the Firestick 4K Max, you need to enable Kodi's access to all files (in the Firestick settings) and then add a source in Kodi's file manager:
special://home
This way, you will have access to all Kodi files (from its file manager).
You select the file, copy it to an unprotected Android folder (for example, Download).
You then download it to your PC and modify it.
To upload it back to Kodi, you follow the reverse process.
Hi @jurialmunkey,
congratulations, your skin is truly fantastic and high-performing.
I have two questions for you:
1) Why are the trailers only visible in "information" and not in the "spotlight"?
2) Why are the provider icons no longer visible, but only those of the studios?
Thank you so much for your work!
Could you share the changes you made please?
(2024-10-20, 17:51)AngryBird Wrote: [ -> ]Got some help from another member in PM.  WIP but getting there.
