2024-10-24, 12:12
@jurialmunkey Can an option be made to display the artist name as clearart? The majority of my artists don't fit in the space provided. Image could be moved just about anywhere too if needed.
(2024-10-25, 10:57)Rf67 Wrote: [ -> ]In Search is it possible(or Can it be editable) that when you insert the search text it opens the search of Other addons rather than tmdb helper? Othervwise you have to create a Shorttcut to search on those addons, and have to reoeat the process with another search box. We loose that beautifull look of the search box on the left side. For me, it s the biggest issue thats annoing me with the amazing skin performance.Hi!
Hope @JM under stand what I tried to exolain, and provide such change. Many thanks
(2024-10-24, 12:12)AngryBird Wrote: [ -> ]@jurialmunkey Can an option be made to display the artist name as clearart? The majority of my artists don't fit in the space provided. Image could be moved just about anywhere too if needed.Hi!
(2024-10-25, 11:42)Officer KD6-3.7 Wrote: [ -> ]utoscroll labels' is en
(2024-10-25, 11:33)Rinicko100 Wrote: [ -> ]I know that, and did it. My issue is that when i insert text on the search box on the left side, only the search from tmdb helper gives a answer. And then I need to do the search again but on the search engine of the Other addon. Is there a way to solve this?(2024-10-25, 10:57)Rf67 Wrote: [ -> ]In Search is it possible(or Can it be editable) that when you insert the search text it opens the search of Other addons rather than tmdb helper? Othervwise you have to create a Shorttcut to search on those addons, and have to reoeat the process with another search box. We loose that beautifull look of the search box on the left side. For me, it s the biggest issue thats annoing me with the amazing skin performance.
You can search other add-ons, all you need is the search path of the add-on, then go to skin settings > under menus > click customise search > Add any item, then change the action to the search path of the addon you want to search from.
(2024-10-26, 01:41)Rf67 Wrote: [ -> ]You may be searching on the discover page instead of the actual search page... Discover page is 1105 and Search page is 1185(2024-10-25, 11:33)Rinicko100 Wrote: [ -> ]I know that, and did it. My issue is that when i insert text on the search box on the left side, only the search from tmdb helper gives a answer. And then I need to do the search again but on the search engine of the Other addon. Is there a way to solve this?(2024-10-25, 10:57)Rf67 Wrote: [ -> ]In Search is it possible(or Can it be editable) that when you insert the search text it opens the search of Other addons rather than tmdb helper? Othervwise you have to create a Shorttcut to search on those addons, and have to reoeat the process with another search box. We loose that beautifull look of the search box on the left side. For me, it s the biggest issue thats annoing me with the amazing skin performance.
(2024-10-26, 02:06)Rinicko100 Wrote: [ -> ]Can you provide a example of how to do that? Hub 1185 is not avaiable for editing. I Can set a com and to activa te Windows 1185, but the how to point it for a search using a addon like fL.. or umb...?(2024-10-26, 01:41)Rf67 Wrote: [ -> ]You may be searching on the discover page instead of the actual search page... Discover page is 1105 and Search page is 1185(2024-10-25, 11:33)Rinicko100 Wrote: [ -> ]You can search other add-ons, all you need is the search path of the add-on, then go to skin settings > under menus > click customise search > Add any item, then change the action to the search path of the addon you want to search from.I know that, and did it. My issue is that when i insert text on the search box on the left side, only the search from tmdb helper gives a answer. And then I need to do the search again but on the search engine of the Other addon. Is there a way to solve this?
(2024-10-27, 10:37)Rf67 Wrote: [ -> ]If you want to use the default search make sure the 'Home > Replace search with discover' setting is disabled. This way clicking on the search icon your home screen will take you to the Search hub (FYI clicking on the search/filter icon below the alphabet row toggles between the two hubs).(2024-10-26, 02:06)Rinicko100 Wrote: [ -> ]Can you provide a example of how to do that? Hub 1185 is not avaiable for editing. I Can set a com and to activa te Windows 1185, but the how to point it for a search using a addon like fL.. or umb...?(2024-10-26, 01:41)Rf67 Wrote: [ -> ]I know that, and did it. My issue is that when i insert text on the search box on the left side, only the search from tmdb helper gives a answer. And then I need to do the search again but on the search engine of the Other addon. Is there a way to solve this?You may be searching on the discover page instead of the actual search page... Discover page is 1105 and Search page is 1185
(2024-10-26, 18:00)himynameisjimmy Wrote: [ -> ]Is it possible to change the default source for trailers?
