(2024-10-27, 13:16)kyrunner Wrote: [ -> ]When I was using Arctic fuse and arctic horizon 2 I could see the Atmos or Dts-hd flag on the video info page. Is there a setting for this on arctic fuse. I only see 7.1 but it doesn’t show if it’s Atmos or Dts-Hd
We have been discussing this on GitHub so check there, I can see your discussion. Not currently available on Fuse 2 though and not sure if it ever will be as per the last time it was spoken about.
(2024-10-26, 02:06)Rinicko100 Wrote: [ -> ] (2024-10-26, 01:41)Rf67 Wrote: [ -> ] (2024-10-25, 11:33)Rinicko100 Wrote: [ -> ]You can search other add-ons, all you need is the search path of the add-on, then go to skin settings > under menus > click customise search > Add any item, then change the action to the search path of the addon you want to search from.
I know that, and did it. My issue is that when i insert text on the search box on the left side, only the search from tmdb helper gives a answer. And then I need to do the search again but on the search engine of the Other addon. Is there a way to solve this?
You may be searching on the discover page instead of the actual search page... Discover page is 1105 and Search page is 1185
I have it on my árctic fuse 1 setup. Dumb me! Thanks for the enlightment. I already have it works ng
I love the new option in the Furniture section - Expanded info panel. You just keep making the skin better! Thanks!
It seems most of the trailers are short clips and not the full trailer. I often find myself scrolling to the bottom of information and selecting the trailer. This was a similar issue for me before using Nimbus skin, but there was an option to change the source from default to MDBList which resolved the issue.
I am unable to see TV show trailers using the Tubed add on but I am able to see movie trailers. Any ideas for how to get TV show trailers to work?
Was playing around with some settings and enabled something where a hub is now the homepage. I'm not stuck in this hub.
Any suggestions for how to leave the hub or get back to the settings window?
I'm now stuck in the hub***
Crisis averted!
I was able to ssh onto the device, delete the guisettings.xml file, and restart the device.
Was then able to switch back to AF2 again and will make sure to not select whatever option I select the first time.
(2024-10-27, 21:03)himynameisjimmy Wrote: [ -> ]It seems most of the trailers are short clips and not the full trailer. I often find myself scrolling to the bottom of information and selecting the trailer. This was a similar issue for me before using Nimbus skin, but there was an option to change the source from default to MDBList which resolved the issue.
The skin does not determine the trailer. The trailer used is specified by your library scraper (for library content) or the plugin you are using.
(2024-10-28, 02:30)boldish Wrote: [ -> ]Crisis averted!
From a hub set as home, you should be able to continue pressing right from the top categories bar to access the options button (as long as you didn't disable it - which might've been what you did, or possibly you set a hub with no categories at all).
Even if you do disable the options menu button, with nothing playing you should be able to press back from the hub to access options. Obviously this is dependent on your device having a button which actually performs the back action on the Home screen (I know on some devices, by default back on home will do the device's app minimise command instead of back)
On the home menu, in each category, when I press Left on my remote, it opens up a side menu. It's just blank, and I don't know what this is called. Is there a way to turn this off, so when I press left it just doesn't do anything at that top level?
I was pressing up, right, back in a bunch of combinations and was legit stuck. (I'm on a Ugoos AM6B+ running Coreelec).
I enabled two options at the same time (I'm stupid) so it's possible that the two together caused this weird state.
Oh, for anyone reading this in the future. My resolution was:
1. Ssh onto my device
2. Delete the GUI settings.xml
3. Restart device (skin should now be disabled)
4. Delete both the add on source folder AND (important) the settings folder for the skin.
If you don't delete the settings folder for the skin, then the issue will persist when you enable the skin again. The settings can only be deleted after the skin is disabled otherwise the settings are re-created and you still have a problem on skin re-install.
Been using AF2 for a while now. Was a bit reluctant at first because I spend so much time setting up AF1.
But I see now how AF1 was a step to the next skin. AF2 is just so much better. It really is a culmination of every Arctic skin before it.
Grats on this amazing skin @
jurialmunkey, and thanks for all you've done throughout the years.
Is there any way I can disable this new side menu on the left? I'm not sure how to edit it or what its purpose is, and it just seems like an extra click that serves no purpose to me.
No automatic trailer in the spotlight, only in information.
Even though it’s enabled in the skin settings.
Has anyone else noticed this issue?
