(2024-10-30, 12:06)Pissa19 Wrote: [ -> ]Sorry for noob question....
How to update library within movie menu?
I can't find the option....
I don't think you can do that... You'll need to create a custom action for it in a menu. It is under kodi commands in the customisation dialog.
go to skin settings > customise options > menu items > click the plus button > go to kodi commands > Update video library
The skin is great, took me some time to migrate from AH2 but it's all good now. Just a little feedback if it's allowed - the library viewtypes could be a bit more diverse. Some of the current viewtypes are a bit cluttered if I could say so or more suited for a music library perhaps. I'm so used to some of the AH2 viewtypes (mostly where the Big poster goes on the left part of the screen with an episode description below that and the big list of episodes on the right part of the screen). It had more air compared to the Fusion viewtypes. If it would be possible to replicate - that'd be an ideal skin for me.
AH2 vs AF2 closest looking (imo) viewtypes comparison
What's the top right number? Is it a rounded value of the different ratings available?
Would it be possible to display the popcorn rating there somehow?
I never asked on the previous skins but is there a way to hide already watched movies from the Top Rated Movies section?
(2024-10-31, 02:09)bamboozilla Wrote: [ -> ]Thank's for your work, the skin is amazing!
The top right number? I think that's the clock 👀
You can hide already watched items by moving downwards multiple times or left (for list views) until you see the filter icons
From there click on the eye icon to switched between showing all items or only unwatched items
(2024-10-30, 16:02)Dzenx Wrote: [ -> ]The skin is great, took me some time to migrate from AH2 but it's all good now. Just a little feedback if it's allowed - the library viewtypes could be a bit more diverse. Some of the current viewtypes are a bit cluttered if I could say so or more suited for a music library perhaps. I'm so used to some of the AH2 viewtypes (mostly where the Big poster goes on the left part of the screen with an episode description below that and the big list of episodes on the right part of the screen). It had more air compared to the Fusion viewtypes. If it would be possible to replicate - that'd be an ideal skin for me.
