(2024-11-07, 14:53)TimboZero Wrote: [ -> ]Is this at a point where you’d like me to raise a bug report, or rather two as edits are not entirely the same as original post issue?
Yes please. Any bugs or requests should be raised on github. It's too difficult to keep track in a forum thread.
(2024-11-07, 13:24)Stuggy Wrote: [ -> ]Another thing is that my OMD and mdbList jeys are not saved. After I enter them in the themovidbhelper v5.3.3 screen they seem to be saved but I exit and go back in and they are blank again.
You probably didn't press the OK button on the right. If you do not press OK then Kodi will not save the settings.
is there any way that i can change the nav bar on the left to the style as in this photo? I looked around the customization menu and didn't find anything. Might have missed it if it is currently possible.
(2024-11-08, 06:04)Dan_of_Earth Wrote: [ -> ]is there any way that i can change the nav bar on the left to the style as in this photo? I looked around the customization menu and didn't find anything. Might have missed it if it is currently possible.
This style was removed a while back but your comment is actually good timing because v2.4.2 updates the icon style again.
The new style is a more "classic" icons only appearance without any backing panel similar in appearance to AF1. It's what I wanted to do originally but there were some issues with masking the widget edges that I wasn't able to solve well enough until now.
(2024-11-08, 01:50)jurialmunkey Wrote: [ -> ] (2024-11-07, 13:24)Stuggy Wrote: [ -> ]Another thing is that my OMD and mdbList jeys are not saved. After I enter them in the themovidbhelper v5.3.3 screen they seem to be saved but I exit and go back in and they are blank again.
I go to skin settings | expert | under dependencies plugin.video.themoviedb.helper
Then down to API keys
I for example type something into OMDB API key and hit enter
It brings up a virtual keyboard which a tick mark at the bottom which I select
Then if I arrow left and go say up to library and then down again to API keys my new key shows
Then I close that window either with ESC or hit the X
Then I go back in and there is no key saved
I looked at the sqlite databases in the userdata but don't see any likely settings database. They seem to be cache db for various things. I was going to try and manually enter it.
(2024-11-08, 12:08)Stuggy Wrote: [ -> ]Then I close that window either with ESC or hit the X
That exits without saving - you need to click the OK button to save.
(2024-11-08, 12:08)Stuggy Wrote: [ -> ] (2024-11-08, 01:50)jurialmunkey Wrote: [ -> ] (2024-11-07, 13:24)Stuggy Wrote: [ -> ]Another thing is that my OMD and mdbList jeys are not saved. After I enter them in the themovidbhelper v5.3.3 screen they seem to be saved but I exit and go back in and they are blank again.
Did you click this button
(2024-11-08, 12:30)Rinicko100 Wrote: [ -> ] (2024-11-08, 12:08)Stuggy Wrote: [ -> ] (2024-11-08, 01:50)jurialmunkey Wrote: [ -> ]You probably didn't press the OK button on the right. If you do not press OK then Kodi will not save the settings.
Thank you for this. I didn't notice it and from the GUI it seemed outside of the dialog. It saves now. Kind of a newbie mistake but visually it didn't seem part of the dialog.
(2024-11-07, 12:53)Stuggy Wrote: [ -> ]I just installed this and am really impressed.
One thing I miss is in the live TV guide view the program plot description does not show unless I go into more information. Is there another TV guide view that provides this?
I got this to work by editing Includes_Views_PVR.xml and adding the plot.
Hey @
jurialmunkey did you decide to scrap the idea of the side menu being adaptive? It looked pretty cool. I see it's been reverted back to what it was originally now it seems.
(2024-11-08, 20:22)Gaddinator90 Wrote: [ -> ]Hey @jurialmunkey did you decide to scrap the idea of the side menu being adaptive? It looked pretty cool. I see it's been reverted back to what it was originally now it seems.
What do you mean by Adaptive? As in appearance wise, having it look like a dialog?
If you set it to "expanded" it uses the dialog appearance, whereas icon uses the more minimal style where the icons just float on the background to make it more consistent with other hubs.
(2024-11-09, 00:09)jurialmunkey Wrote: [ -> ] (2024-11-08, 20:22)Gaddinator90 Wrote: [ -> ]Hey @jurialmunkey did you decide to scrap the idea of the side menu being adaptive? It looked pretty cool. I see it's been reverted back to what it was originally now it seems.
The on left custom menu animation was also pretty good... the way it pushed everything to the right and appeared beside the side menu
I'm not sure if it's a bug then as I have it set to expanded and when i applied the latest update last night it was not matching the dialogue like it did in a previous update
