jurialmunkey would it be possible to change it back to having it set to icon would also have the adaptive look, it looked really cool like that.
Is there an option to change watched/unwatched colour?
(2024-11-09, 11:19)Blurayx Wrote: [ -> ]Is there an option to change watched/unwatched colour?
Go to Skin Settings > Go to Appearance > Go to Customise highlight colours and click on it > it will open a dialog with various options, go down to where it says "Customise" and click on it > Click on the arrow till it focuses on "indicator"... then you can change the colour
one of the best skins I've ever tried in my life! I just wanted to ask which xml file to edit to remove the arctic fuse ² writing in the startup, I put the photo of my son and I would like to see only him when I turn on
. thanks.
(2024-11-09, 18:31)Terre45y Wrote: [ -> ]one of the best skins I've ever tried in my life! I just wanted to ask which xml file to edit to remove the arctic fuse ² writing in the startup, I put the photo of my son and I would like to see only him when I turn on . thanks.
Try making a short video and using that instead... If you edit the xml file, you'll have to do that after every update.
jurialmunkey
Are we now unable to make widget only Home?
Assumptions. We can only make widget only hubs in 1101-1109 using Detailed mode, once a custom hub is made Home it is removed from hub list, once a custom hub is set as Home it is forced to Advanced mode (hence no longer widget only possible) and mode change setting for Home is removed.
I understand (after our chat on GitHub) the reason for the changes but is this ‘side effect’ intended or unintended?
Edit.. never mind, issue resolved with release of 2.4.6. Thank you for this change and your continued work of AF2, such a great skin it’s impossible to use anything else (especially impressive for a skin still in alpha phase)
THANK YOU it work!
i had to disable "hide loading widget" so that only the video would appear! thank you so much indeed
I have this set up on 2 PCs.
On one PC the background art for movies and tv shows shows up nicely. On the other which I think I set up the same I don't see background "fanart". The ratings show, the movie title is replaced with a nice movie specific font but I don't get the background images. What setting am I missing? The resolution on the other PC is a bit lower but that shouldn't affect it.
Any ideas?
Update: It looks like I worked it out after more digging. Under skins - appearance - background style. I changed it to blur from fanart that I think I had set it to and now fanart shows.
Is Arctic Fuse 1 completely abandoned? Seems premature.
jurialmunkey
Was the option to disable expanded info displaced? I can't find it under Furniture settings anymore.
Does anyone know what the icon is beside the 5.1 audio icon? It's appearing on approximately half my films.
