Full Version: Arctic Fuse 2
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
(2024-11-15, 20:33)zackstar Wrote: [ -> ]@jurialmunkey
I really love the skin. It is by far the best out there for me.
Is it possible to add the play, trailer and trakt button to the info screen. Instead of having a side menu.
These buttons up here to put them somewhere down here.
Thank you for all your hard work. Love the skin.
^^ meant to quote this
Former AH2/AF user trying this out! I use PVR heavily--was the option removed to get artwork lookups in the Guide? I see there's the view that brings up the channel icon and info on the side, but you have to go into the information to see the artwork (and there's no way for the show title artwork to show up)
(2024-11-17, 04:57)raiderox Wrote: [ -> ]Former AH2/AF user trying this out! I use PVR heavily--was the option removed to get artwork lookups in the Guide? I see there's the view that brings up the channel icon and info on the side, but you have to go into the information to see the artwork (and there's no way for the show title artwork to show up)
It's still there (Skin Settings > Details > PVR > TMDbHelper Lookups) but your comment made me realise that I've introduced a bug where the background isn't working properly anymore for Guide/Channels (but it still works on widgets).
Was a small oversight where I forgot Guide/Channels don't have a content type (and the background hides if the content type is empty, hence the lack of fanart). It'll be fixed in next update.
You're correct though that there is no longer half sized flixart style view for Guide that shows the info in the top half. I found that while aesthetically it looks good (assuming you get a good artwork match), in practice it isn't very functional to have a guide with only four rows. Plus the info/art lookups are a bit hit and miss, which ends up confusing if the clearlogo is for the wrong show. So that's why I switched it out in favour of a full size grid with the side panel instead.
Has this the Kodi command option been removed?
AF
Hi
Is there any way to not show a profile icon at the top of the screen? Is there a setting to turn it off (circled in yellow)?
(2024-11-17, 05:52)jurialmunkey Wrote: [ -> ]It's still there (Skin Settings > Details > PVR > TMDbHelper Lookups) but your comment made me realise that I've introduced a bug where the background isn't working properly anymore for Guide/Channels (but it still works on widgets).
Thanks, the background is indeed fixed up now 👍🏻. I think the full size grid is growing on me, it is definitely more functional like you said. How do you feel about showing the clearlogo in the side panel if artwork lookups for PVR are enabled though? The background is there in the guide after all, and clearlogo also comes up for PVR widgets but not in the guide.
(2024-11-17, 18:53)Blurayx Wrote: [ -> ]Has this the Kodi command option been removed?
No, it is still there. Works fine for me.
(2024-11-17, 21:11)Chalklands Wrote: [ -> ]Hi
Yes in Skin Settings > Menus
Anyone having trouble with displaying the rating in AF and AF2. I added OMdb, mbdlist API key but only TVDB rating is showing on AF2 and Trakt on AF. I need my IMDB rating. TIA
(2024-11-18, 03:47)Oriental_Noodle Wrote: [ -> ]Anyone having trouble with displaying the rating in AF and AF2. I added OMdb, mbdlist API key but only TVDB rating is showing on AF2 and Trakt on AF. I need my IMDB rating. TIA
Working fine for me.
Things to check:
1. That you entered your keys correctly (sometimes can accidentally have a leading or trailing space that you miss).
2. That you pressed the "OK" button to save the settings in addon settings dialog (found on the right side of the dialog - if you press back to close the dialog then Kodi does not save the settings).
3. That you actually selected the ratings you want to see in Skin Settings > Details > Ratings (the defaults are Kodi/TMDb/Trakt - so if you didn't change them to show IMDb then that's why...)
(2024-11-18, 00:58)jurialmunkey Wrote: [ -> ]
Thank you!
Great skin!
Is there a reason why only the Advanced hub mode shows spotlights?
(2024-11-18, 20:20)Chalklands Wrote: [ -> ]Hi,
Great skin!
Sorry I don't really understand what you're asking here.
That's literally what advanced mode does...It sets the hub to allow advanced features such as spotlights and categories (ie so the hub is more than just widgets only).
Deleted
Deleted
