(2024-11-26, 09:37)Dan_of_Earth Wrote: [ -> ]I seemed to have lost the rewind icon on the player?? It seems to instead be "previous file". I cant seem to find a setting to change it. Anyone have any idea?
If you press up from the left side buttons (Play/Prev/Next/Stop) then you can access the seekbar scrubber where you can press left/right to seek backwards/forwards.
Hello Jurialmunkey ,
First of all : This skin is awesome. Thanks for making this.
But i have a question , regarding the font size. Is it possible to reduce or enlarge it ?
I use text for the names of the movies and series , but is seems that the font
is too big too show the whole text.
I don't want to use the clearlogo's instead.
Also the font used for the plot is too big , for me.
Is there an easy wax to fix this ?
I hope you understand what i mean.
Greetings from The Netherlands.
Is there a simple way for me to clear some glitched fanart in my cache?
Awesome work as always...
I remember there was a setting to disable clearlogo/text of movie title above the seek bar, now I can't find it.
Does it still exist somewhere? Thanks.
jurialmunkey Love what you did to the video info dialog in the newest version!
(2024-11-21, 00:00)jurialmunkey Wrote: [ -> ] (2024-11-20, 21:53)Blurayx Wrote: [ -> ]@jurialmunkey
A few months ago, you kindly told me how to change the episode formate from 2x1 to E2 S1(settings.xml). With the latest AH2 update, it has stopped working. No issues with AF & AH2.
Has something changed with the latest update?
I have switched to using the proper default labels and I cannot control how kodi or other add-ons format them.
This feature needs to be requested for kodi itself to allow formatting season and episode numbers in a different way.
Update: Completely removed Arctic Fuse 2. You have done a wonderful job over the years with your skins, always progressing but find AF2 somewhat limiting. Now using Arctic Fuse Mod. I prefer the more user-friendly pre-configured wizard setup options. It does everything I need, including changing the episode format. 😀
Thanks for the great work as usual but cant install it. I am running KODI @ Mi Box S 4k installed at SSD 2.5"
Always getting error with zip file while trying to install - failed to install addon from zip file - then the entire app crashes.
Just outstanding. This is your best work so far. Thanks a lot
I've been out of the loop on skins development, wanted to try a couple of jurialmonkeys new ones, installed the repository, install AH2 fine, but AF2 complains of TMDBhelper version being a conflict ? What s required to cure? Thanks to JM for his time and his eye .
Scratching my head over this.
I'm trying to add android apps into the skin - What I mean is when I select say Netflix or Prime, the app opens outside of Kodi. It works if I go into favourites and select them from my favourites list, but I can't work out how to add them either as a category or a widget in the skin in my Home hub.
I can add them as categories and they show up in my category list, but when I select them nothing happens. Am I missing something?
(2024-12-01, 21:05)christoofar Wrote: [ -> ]I've been out of the loop on skins development, wanted to try a couple of jurialmonkeys new ones, installed the repository, install AH2 fine, but AF2 complains of TMDBhelper version being a conflict ? What s required to cure? Thanks to JM for his time and his eye .
Follow all the instructions in the first post... You haven't allowed installing repo dependencies from unknown sources or you have done a manual install or you have disabled updates.
Specifically, these steps were not followed:
1. Enable "Unknown Sources" in Kodi Settings > System > Add-ons
2. Enable "Update official add-ons from: Any repositories" in Kodi Settings > System > Add-ons
You must follow instructions to install from unofficial sources BEFORE installing the skin. If you have manually installed a dependency or disabled auto updates then you need to use the versions button from that dependency to track the repo again.
I know I've seen someone bring this up before, somewhere, but I cannot seem to find it. Apologies in advance for the duplicate query.
What do the slash and pipe characters mean in the info line? Am I missing a dependency? Incorrect setting somewhere?
(2024-12-02, 01:18)NolanGrayson Wrote: [ -> ]I know I've seen someone bring this up before, somewhere, but I cannot seem to find it. Apologies in advance for the duplicate query.
It means the movie is part of a collection or has other parts
The skin is just amazing, @
jurialmunkey. Faster than AF1 or AH2.
Is it possible to do on the widgest and sportlights the same thing you've done on the videoinfo OSD, concerning the label of the item (Movie, TV Show, Episode, video format and audio format) , instead of the "WEB" or "LIbrary" ?
Other than that, could you add a few more types of fonts to choose from? And, finnally, when a Kodi Piers version?
If this could be achieved, in my opinion, you've reached perfection with this skin.
Thanks for all your hard work and your sharing.
Rui (Portugal)
