2024-12-02, 18:35
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
2024-12-02, 20:04
Constructive feedback all pertaining to the hubs/widgets.
1. Amazing work AGAIN and thank you for volunteering to consistently make the most professional looking interfaces on Kodi... by far.
2. 2/3 of the widget styles (detailed and advanced) have more than enough metadata on the information panel, therefore any text metadata (title, episode) repeated on the widget style is redundant. While there are several widget styles that only present a thumbnail in various dimensions, I think an alternate landscape style with no text would be great. I know I'm describing board and card, but they're much larger than the basic landscape style.
3. Skin is missing the text only style for items that won't have a unique logo/icon/image.
4. Optional context menu item to reload a widget on demand might be useful.
2024-12-03, 01:08
(2024-12-02, 20:04)NolanGrayson Wrote: [ -> ]Constructive feedback all pertaining to the hubs/widgets.
1. Thanks
2. The widgets with plot etc. details are intended for use in Basic layout which does not have an information panel. The technical limitations preventing smaller sized widgets have been discussed on github ad nauseam
3. See 2
4. Not possible. Skins don't control when widgets reload.
2024-12-03, 01:14
@jurialmunkey , i’m missing the record button in guide windows (only se timer) Is it not ready yet or am i missing some setting?
2024-12-03, 01:20
(2024-12-02, 12:53)RmdcF1967 Wrote: [ -> ]Is it possible to do on the widgest and sportlights the same thing you've done on the videoinfo OSD, concerning the label of the item (Movie, TV Show, Episode, video format and audio format) , instead of the "WEB" or "LIbrary" ?
Are you talking about resolution and number of audio channels in the info line? That already exists in the library and works fine for me. Kodi only provides that info automatically for local files in your library. You won't get it from plugins unless the plugin specifically adds that information.
(2024-12-02, 12:53)RmdcF1967 Wrote: [ -> ]Other than that, could you add a few more types of fonts to choose from?
Are you serious There's already six fonts sets. That's more than a big enough PITA for me to manage....
(2024-12-02, 12:53)RmdcF1967 Wrote: [ -> ]And, finnally, when a Kodi Piers version?
No reason why the skin can't work on Piers already. Just needs a GUI bump to allow installing.
If you're asking for a repo version, that wont happen until Piers is at least at alpha stage....
At the moment Piers is pre-alpha so asking for a Piers version is jumping the gun a bit -- if you're unable to manage the GUI bump to install it on Piers manually then you probably shouldn't be using a pre-alpha development version of Kodi anyway.
2024-12-03, 01:26
(2024-12-03, 01:14)Jönke Wrote: [ -> ]@jurialmunkey , i’m missing the record button in guide windows (only se timer) Is it not ready yet or am i missing some setting?
Context Menu > Record
You're right though that the button is missing from the PVR info dialog.
EDIT: Looks like a small typo stopping it from displaying. Will fix now.
2024-12-03, 09:13
@jurialmunkey
Thank you for introducing the feature auto trailer. I enabled automatic trailer only for widgets and so far I have no problems. Is it possible to add after how many seconds the trailer starts. At least I don't see such a feature. Thank you once again.
2024-12-04, 16:04
On both AH 2 and AF2, I'm seeing trakt and mdb connection errors. Is this something skin related?
2024-12-05, 08:09
Hmm, I'm trying to install this on a fresh instance of kodi, and it's telling me it needs TMDB Helper version 5.4.8, and won't install as it can't meet that dependency. What am I doing wrong here
EDIT: Ah, for anyone else who runs into this, just needed to go into Settings > System Settings > Add-ons and change "update official repositories from" to any repositories. Easy to miss these little things that you set years ago and then forgot about when you do a fresh install
2024-12-05, 08:20
(2024-12-05, 08:09)simonk83 Wrote: [ -> ]Hmm, I'm trying to install this on a fresh instance of kodi, and it's telling me it needs TMDB Helper version 5.4.8, and won't install as it can't meet that dependency. What am I doing wrong here
Looks like my tmdb version is 5.2.25, and the one in jurials repo is 5.4.15 but I can't install that either due to the dependency on script.module.jurialmunkey 0.2.2 missing (which I can't find)
both of those are on jurial's repo which can only mean you didn't follow the instructions from the first post telling you to install his repo first and then allow install from 3rd party repos
follow all instructions provided https://forum.kodi.tv/showthread.php?tid=379015
2024-12-05, 17:42
(2024-12-03, 01:26)jurialmunkey Wrote: [ -> ]Still no record button in v2.4.30, if it was ment to be working now?(2024-12-03, 01:14)Jönke Wrote: [ -> ]@jurialmunkey , i’m missing the record button in guide windows (only se timer) Is it not ready yet or am i missing some setting?
2024-12-05, 17:50
been using this skin for a few weeks now, coming from AH2. after a few days getting my head around it, love it. Big Thanks.
liitle? if any could help. click on movies for my library , all Good bar 1 thing. on movie set's won't show any plot info.
all in right order ect, worked great on ah2. anything i am missing here would be great.
2024-12-06, 01:11
(2024-12-05, 17:42)Jönke Wrote: [ -> ](2024-12-03, 01:26)jurialmunkey Wrote: [ -> ]Still no record button in v2.4.30, if it was ment to be working now?(2024-12-03, 01:14)Jönke Wrote: [ -> ]@jurialmunkey , i’m missing the record button in guide windows (only se timer) Is it not ready yet or am i missing some setting?
Commit was made after that release. It will be in 2.4.31
2024-12-07, 12:14
My apologies if this has already been discussed or if I missed it somewhere.
Is there a wiki that provides a breakdown of all features and advanced setup instructions for this skin?
I am aware of the tutorial video posted on YouTube which is great but, I would love to have an actual wiki I can easily jump back to for reference. It would help a lot with ideas I have using different features while working on my custom build for this skin.
With so many options it's not hard to forget some, or even find new ones along the way. I'm not having issues with the operation of the skin or anything, just remembering and being aware of what all is possible with in AH2.
Thank you again for bringing such a valuable addon to the community.
2024-12-07, 22:47
Easy switchover and looks nice.
I've noticed that in the info page for movies it's showing "Episodes (0)" in the block of info which I assume shouldn't be there for movies.
Also wondering if there's a way to get that area in the lower left back on the info page that showed the icons for all sorts of things like aspect ratio, video encode, audio format, atmos, surround channels, flags for audio/subtitle tracks etc. I believe it was in there in Arctic Horizon 2 (and maybe Zephyr?).
Just wanted to make sure I didn't miss some setting.
