Full Version: Arctic Fuse 2
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
ARCTIC FUSE 2
It's been a minute...
I've been quietly working on a second iteration of Arctic Fuse.
AF2 significantly simplifies Arctic Fuse with the aim to provide a more "classic" Kodi experience. In particular, that means it (finally) brings some of those long requested features such as proper wall views, simple home screen widgets, and info dialogs with big poster art.
Some more experimental features have been dropped in the process. I've had to make some tough decisions. That means it won't please everyone but I think most people will find the simplification generally welcome and will see that it makes a lot sense in terms of a smoother and more consistent experience.
Installation
The skin and its required dependencies are available on my 3rd party alpha repository.
Requires Kodi Omega or higher.
Kodi File Manager Source:
https://jurialmunkey.github.io/repository.jurialmunkey/
Direct ZIP Install:
https://jurialmunkey.github.io/repositor...ey-3.4.zip
Instructions:
1. Enable "Unknown Sources" in Kodi Settings > System > Add-ons
2. Enable "Update official add-ons from: Any repositories" in Kodi Settings > System > Add-ons
3. Install my repository using either the zip or file manager source linked above
4. Install the skin from my repo: Jurialmunkey Alpha Repo > Look and Feel > Skins > Arctic Fuse
If you like my work and want to support me, you can buy me a coffee on Ko-Fi
https://ko-fi.com/jurialmunkey
Bug Reports and Feature Requests
As this is an alpha release, you should expect occasional bugs. Please report bugs and missing features by creating a new issue on github.
Additional Ratings
Ratings from IMDb, RottenTomatoes, and Metacritic require a personal OMDb API key and/or a personal MDbList API key
You can get a free key from
https://www.omdbapi.com/apikey.aspx
https://mdblist.com/preferences
Enter your API key(s) in TMDbHelper settings
Skin Settings > Manage Dependencies > plugin.video.themoviedb.helper > API Keys > OMDb API Key
Skin Settings > Manage Dependencies > plugin.video.themoviedb.helper > API Keys > MDbList API Key
OMDb = Tomatoes, IMDb, Metacritic (movies), Critics consensus, Awards
MDbList = Tomatoes, IMDb, Metacritic (movies + tvshows), Letterboxd (movies)
More Screenshots
Discover
Expanded
Plot
Wall
List
Scrollbars
Filter
Combined
Overview
Cast
Simply outstanding! Can't get more excited to test it. Many thanks, man
very exciting news.
Here we go again, looking forward to it !
Looks amazing 👏👏👏
I'm eager to test and hope it will be quick to use
Can't wait to try this new iteration of Fuse, it definitely looks more streamlined which is awesome Cool
Thanks as always J, knew there would have been a reason for the quiet. Look forward to testing.
@jurialmunkey, long time fan and been using your AH2 since I got a Vero 5 with enough power to use it without slow downs and it’s a beautiful skin.
Just 3 mins into a first look and minimal (added 2 home menus, removed one) tinkering, and love the skin a lot and maybe enough to convert me from AH2 to AF2 today. It’s that good.
For those that are curious but haven’t tried it, it’s (hate to compare as it’s unfair) like JM had written Estuary and put his usual customisation and widgets into it. If you like how clean Estuary is but wish it was more flexible don’t think twice add this skin!
@JM sorry for that clumsy comparison but I hope it gets you a few converts as you historically deserve more props and for this skin deserve a lot of users/followers!
The skin is amazing. I have 2 Kodi setups on my Shield, one with AF 1 and Fenlight widgets, the other is this AF2 with TMDB Helper widgets. Both beautifull and full of resources. Many thanks from a true fan @JM
@jurialmunkey
Now fully a convert from AH2 to AF2 (mostly because of how damned fast it is, and a little for it being cleaner but as customisable)
I do however (as a new user, and a newb) have 3 questions about config…
1) can I add a main menu item (or any combo of menu/widget/etc) for what appears in favourites.xml as RunAddon(“script.launch.retropie”) to AF2?
2) can I have a (like tv and movies titles) widget for favourites (which I tuned the command to ActivateWindow(favouritesbrowser) because I like that format more)
and finally
3) can I please turn off that profile name at bottom of expanded main menu next to the Kodi icon, and if not would you please consider it as an option for next version please? (seeing Master User just feels egotistically wrong to me lol)
Additionally in the ‘please add to next version’ category, could we have some default background images for movies,shows etc (I mean know inv you it’s already in there and I just have to add a dependency or change a config somewhere)
It's fantastic. I've already moved over from Fuse 1. I've set it up on my tablet and it works great.a lot smoother than the original, which I really like. Thanks again!
Great work as always, super excited to try this. Thank you!!!
