Full Version: Astra 28.2E Freeview channel changes...
Specifically ITV2HD - ITV3HD and Film4+1. The latter WAS available freeview but not sure if that changed with channel shift.
Trying to work out how to update my channel list.
Help please
Please post support questions for NexPVR backend on the NextPVR forumYou will need to explain more information ie what platform and tuner you are using, DVB-S or SAT>IP
I had same issue and had to download an updated frequency file (0282.ini) from kingofsats website
It depends the .ini files only work with Windows or with SAT>IP not LE.  New ini on v7 too, hopefully it works better (it is half the size of the kos file hopefully I got all FTA.
Best to post backend issues on the NextPVR forum.
Martin
