I could not find anything for creating music videos playlist in the forums or wiki. how would i do this?
It works pretty much like your music playlists. You can queue up a bunch of videos (using 'q'), switch to current playlist (spacebar) and save it giving it some name. If you want more control you can use smart playlists.
you rock I do not use the keyboard for xbmc maybe i should now. I take it there is a key layout in the wiki. Thanks for your help.
The info you need should be
here, while Xbox centric it should contain everything you need (along with
this.)
