Full Version: Type to find support
Is there anyway to add type to find support for this addon?
It would make navigating long lists a bit more tolerable.
Kodi supports it in the library mode.
(type to find is holding Shift and typing the word to jump to that title)
It would need to be a feature available to all PVR.
Do you mean functionality similar to search at the top level?
When you're in the library view and you press shift plus a letter it will jump to that letter in your library. I'm inquiring about the same type of functionality in the listing for PVR either in the EPG guide or the channel listing. So that I can press shift T and be taken to say TNT sports for example Rather than arrowing down all the time.
I realize the remote control app for smart phones lets you instantaneously search and find channels that you want, but it would be pretty convenient to be able to do this within the app
In the channels view, in name order it should jump by shift T today.  In number order it would be kind of odd since it isn't alpha order so it would need to be indexed.
Interesting. It is working in Channel view, just not EPG. That is fine. I'll use channels when I need to quick find a channel.
