Full Version: Broken Photos with kodi-20241229-53995306-master-arm64-v8a.apk
Hello everyone,
I usually just grab the latest master development apk and install it on my Shield. Unfortunately, this time the latest master is broken and Photos over SMB do not work, a popup window appears asking for username/password.
Movies, TV, Music all work fine over SMB connection, only Photos is broken.
Any ideas please?
Thank you.
PS:
happy new year!
Hi, please provide a debug log where you access a Movie and Photos via SMB: https://kodi.wiki/view/Log_file
What happens if you enter the requested credentials? If your share doesn't require credentials, what happens if you try to continue without entering credentials?
Possibly related change, though I would then expect it to not work for Movies etc. as well: https://github.com/xbmc/xbmc/pull/26165
Can you try this previously nightly that doesn't include above change? https://mirrors.kodi.tv/nightlies/androi...64-v8a.apk
(2025-01-01, 11:15)ZombieViewer Wrote: [ -> ]this time the latest master is broken and Photos over SMB do not work, a popup window appears asking for username/password.
ask password is not = broken
Please provide this username/password.
Note that in Windows 10/11 (in case of SMB server is Windows based) not exists the concept of SMB access without user/password. Even if a folder is shared with "everyone" user this means --> "all users have access" but you still have to provide a user.
If you want:
user = guest
pass = 1234
but not allowed empty user/password.
(2025-01-01, 15:28)Neo1973 Wrote: [ -> ]Possibly related change, though I would then expect it to not work for Movies etc. as well: 26165 (PR)
This does not change the conditions for credentials to become invalid. The only change is that instead of failing silently (only in the logs) or with an uninformative error message, the credentials are now requested in a visible popup.
This means that if the credentials are now requested, the access did not work before (the server returned an error anyway).
What can happen is that if you have several image sources, only one of them may fail (maybe it is not even in use) and this will go unnoticed.
The solution is in any case to provide the missing credentials or delete that source if it is no longer used or does not exist.
