2025-01-03, 15:42
Hello everybody!
I'm using latest Lubuntu + kodi to use an old pc as a tv: it could be great but in the (free!) channel list I use here there are some channels that stream at 1080p (even though, on those streams, it is possible to manually select a lower resolution streaming) while this pc won't stream properly things above 720p: is there a way to prevent the system from loading resolution higher than 720p or force all streams to the same resolution (if possible)? Tweaking inpustream adaptive didn't work , nor it did trying to select a 720p and then entering video settings and setting it as default for all media.
any hint? main resolution in settings is 1280x720
Thanks for the great work anyway!
