2025-01-05, 10:52
Xperience1080 10.x is for Kodi 21.x "Omega" only
Installation
Install from GitHub (unstable version)
If you can't wait for the official release of the skin for 21.x Omega in Kodi add-on repository, you can manually install the latest skin revision from GitHub.
NOTE: The flat theme is only available in the packaged version of Xperience1080 you get from the official Kodi add-on repository.
Here is how:
Issues, release history and contribution
Please use Github if you want to contribute or report issues.
https://github.com/xperience1080/skin.xperience1080
Thank you to:
Screenshots
Installation
- Download Kodi 21.x "Omega"
- Go to Settings -> Interface Settings -> Skin -> (Select current skin) -> Get More... -> Xperience1080
- The skin and dependencies will now be installed, this may take a few minutes.
- You will be asked if you would like to keep the new skin, select Yes.
Here is how:
- Download the zipped skin: https://github.com/xperience1080/skin.xp...master.zip
- Start Kodi and go to Settings -> Add-ons and select "Install from zip file". Browse for the file downloaded and press "OK".
Thank you to:
- Piers
- `Black
Screenshots
