Full Version: IRTRans + MCE remote, how?
Pages: 1 2
quick question re: this. i have a Zalman HD160 with an MCE Remote. i've already got this working pretty well using Myxin's method in post #2.
something i'm having trouble with, though: these specific buttons on my MCE remote:
teletext
guide
red
green
yellow
blue
do not seem to work when i add them to the apps.cfg file and then map them to a keyboard button. can they be added? is there a specific way to enter them? all the other MCE remote keys work fine. note that this is NOT the same issue as my post above - i have tried mapping them to a basic letter key.
thanks...
I think the IR Trans don't know the buttons.
Right click on the IR Trans tray symbol and choice "show IR command"
Press one of the buttons without function.
You should see something similar to this: S000111010001
Right click on the IR Trans try symbol and choice "learn IR command"
Choice you remote controlle from the list, enter the name of the button and press learn. Now press the button on the remote.
Hi all,
in the latest version of the IRTrans server we have added native support for IRTrans together with XBMC. By default the MS MCE remote is used.
However, another remote can be used by editing the apps.cfg file.
IRTrans
IRTrans: I am thinking of buying an Origen AE VF110 from ebay
http://www.origenae.co.kr/en/accessory_vf110.htm
It uses the Ir trans server, will the VFD also work out of the box with the XBMC plugin?
Pages: 1 2
