Full Version: Sleep mode
Anyone having issues with the PC going into sleep mode, while xbmc is running.. my PC goes to sleep fine, when xbmc is NOT running..
I checked the idle sleep option, tried it with it on and off.. also disabled the screensavor and still no luck..
any ideas??
Bump.. anyone!!!
You can trigger sleep modus from within XBMC.
It could be that SDL prevents sleep mode when triggered from outside or windows itself.
how can i do that from within XBMC
Look under the shutdown setting in the GUI, it is called "Suspend"
