Full Version: XBMC (application) restart failed
When xbmc is restarted (only applicaion not the pc) from the UI or forced to restart using ctrl-alt-backspace, the fluxbox windows manager will start up instead of XBMC.
Other users has experienced the same problem.
known bug, fixed already for the next release.
Tks for the notification.
l.capriotti Wrote:known bug, fixed already for the next release.
Could you point to the fix? Thanks.
inside runXBMC.sh, insert the lines creating the file /home/xbmc/.xsession within the endless loop, ie after the "while true".
l.capriotti Wrote:inside runXBMC.sh, insert the lines creating the file /home/xbmc/.xsession within the endless loop, ie after the "while true".
Thanks. I will have a look.
