Full Version: Incompatible skin. We require skins of version 2.00 or higher
I'm trying to run the MediaStream skin om my Linux Atlantis Beta1 release.
I've downloaded and installed the latest version of XBMC (via ppa-sources).
I've downloaded the MediaStream skin from http://www.teamrazorfish.co.uk/mediastream.html.
Copied the MediaStream folder under /usr/share/xbmc/skin.
If I want to change skin with my resolution set to 720p, xbmc comes back with the message :
What is going on / What am i doing wrong here ?
--EDIT--
The exact same MediaStream skin DOES work on a regular XBOX (Latest T3CH distro) -- I like the CoverFlow View !! Way 2 GO !!
But apparantly this skin does not work on a Linux XBMC distro
--EDIT--
Thx !
Put the skin in /home/user/.xbmc/skin
Thanks ! That is the solution indeed !
