wiggley Wrote:I went to the appleTV Xbmc update menu and chose the application. I'm still getting the same error right after the logo disapears. Don't know if it matters or not but I don't hear the music anymore when the logo is displayed. Error: XBMC/Boxee exited with a status: 10. Do I need to delete the application first ? Thanks for all your help.
1) reboot the appletv (this starts a new console.log file)
2) go into the xbmc launcher update menu and update to beta1 again.
3) do nothing else except scp the console.log file and post it to a pastebin site
wiggley Wrote:Console.log http://pastebin.com/d19585e9a
So far so good, no problems that I can see.
Now do the same thing but this time launch XBMC and post the console.log and xbmc.log
wiggley Wrote:Console.log http://pastebin.com/d5b901cf5
xbmc.log http://pastebin.com/d5b13696e
Looks to be a problem with your usersettings. I would delete them and start fresh.
usersettiing are in
/Users/frontrow/Library/Application Support/XBMC
delete the entire XBMC directory there.
Quote:rm -rf /Users/frontrow/Library/Application\ Support/XBMC
Then try the launch of XBMC again. same procedure to clear the logs.
has the exakt same problem like the rest of the people in this thread.
Getting the status 10 error or just that the startingscreen freezing
johanbolle Wrote:has the exakt same problem like the rest of the people in this thread.
Let's take this in steps,
You launch XBMC and what was the result?
1) No IR control
2) XBMC crashes and you get status 10 back
3) something else
2.
and i did exactly this:
Originally Posted by wiggley
Console.log
xbmc.log
usersettiing are in
and now it works
I'm good now also. I tried to change my settings one at a time and back out after every change. I think the problem is with the Project Mayhem III skin. I'm using the default skin without incident. Thanks for all the help. I learned a lot along the way.
I'm getting the same Status 10 problem. I restarted my Apple TV and deleted all the non-necessary files from my user folder, but it still happens.
Here's what I've done so far. I installed the ATV USB Creator and then did all the updates for XBMC and Boxee. Then I installed Python. Then I put the Veohproxy script into the script folder. I then put the NinjaVideo plugin into the video plugin folder. I then turn on the Veohproxy script, then run the NinjaVideo plugin. Sometime when I'm loading a video or moving around the menus, a black screen shows up and then the Apple logo comes on for a second. After that it says that XBMCE/Boxee quit with status: 10. I'm uploaded my console log and XBMC log to pastebin.
Console -
http://pastebin.com/m42704071
XBMC -
http://pastebin.com/m19e40395
Any help would be greatly appreciated. By the way, these problems only happen when I'm using the NinjaVideo plugin, everything else works perfectly!
Thanks!!!
shuki18 Wrote:I'm getting the same Status 10 problem. I restarted my Apple TV and deleted all the non-necessary files from my user folder, but it still happens.
Console - http://pastebin.com/m42704071
XBMC - http://pastebin.com/m19e40395
need to see
/Users/frontrow/Library/Logs/CrashReporter/CrashReporter.log
scp it out and paste to
http://www.pastebin.com
